Originally posted by Ormand
Of course, as soon as the car starts to move, there will air flow past the IC, to cool it off, plus the air flow generated by the little fan on the crank pulley. The stock IC, especially with a big neck, is good for most any power level the stock turbo will provide. (numbers I've seen are much better than the 20% mentioned by boost creep.) Once you get into higher flows than the stock turbo, then there will be more advantages to a bigger IC, and you can weigh the advantages of an FM vs a stock location. but, as Killrv6 mentioned, if you don't like an intercooler, it is possible to make up the power loss by using alky injection, and other power boosters. Of course, if you used them WITH the IC, you would have even more power.
If you mean 65+MPH as starts to move. It takes alot of airflow to start to cool the stock intercooler. And without the fan it just about won't do any cooling at less then 70 MPH. I only mention this as having actually relocated the MAT, and watched what happens.
Riddle me this. If the stock turbo puts so much heat into the charge, then wouldn't a F/M be most effective on a turbo that was generating the greatest increases in MAT temps?, ie the little stock turbo?.
The only way an Intercooler is effective when it gets to be effective. Having the radiator discharge air blow against the shroud, heats the shroud, and that heats the intercooler, or mins the temp difference across it. If in doubt touch the shroud, it gets toasty warm. And the main reason it's cooler then the radiator discharge air is that it's shedding heat into the air being srawn thru it.
As I showed in some data logs, Alky injection offers all the advantages of F/M for a street car. On a 1/4'er you spend the last 1/2 of the track at high enough speeds that a F/M can start to be effective, in actually shedding off some heat. But, that second half of the track is generally above the speed limits other then in Montana.
Using Alky with a F/M just lessens the effect of the Alky. Alky takes heat to vaporise, so the only effect the alky will really have is in the combustion reactions. And for that water will work just as well, and possibly better, from some stuff I've looked at.
And there may be issues with using Alky or water injection pre Intercooler. ie the AL may get oxidized, and form a heat barrier, on the inside of the intercooler, and that would seriously hurt it's ability to transfer heat.
