87 WE2
- Jun 28, 2002
Putting the word out there that my old T-type is for sale, current 3rd owner is an older gentleman out of Lower Delaware. He is not much of a computer person so I told him I would post this for him, he has taken great care of this car, in the last two years since I restored/owned it. PLEASE DO NOT POST A REPLY. CALL HIM DIRECTLY AND OR E-MAIL.
The car is an 1986 Regal T-Type
COLOR – LIGHT CHESTNUT MET. (EXTREMELY RARE)
HARDTOP CAR, 3 OWNERS, Del INSPECTED.
Car has Aprox. 85,000 on it. I should know the exact mileage soon.
For Sale at $19,000 over $21,000 invested
Aprox 5000 MILES ON THE CAR SINCE RESTORATION WAS COMPLETED.
**NEW EVERYTHING: ENGINE,TRANS,PAINT,INTERIOR,WEATHERSTIPPING, ETC…**
HE HAS ALL RECIEPTS, BEFORE & AFTER PICTURES TO VARIFY ALL WORK THAT WAS DONE.
ALL RECIEPTS GO WITH THE CAR IN A FULL 2" THICK BINDER.
SOME OF THE CARS OPTIONS:
ELECTRONIC CLIMATE CONTROL (RARE)
POWER ANTENNA
POWER 6 WAY 55/45 SPLIT BENCH SEAT (RARE)
MAP READING LAMPS
NO CRUISE WHEN ORDERED (RARE) HOWEVER I DID ADD THE “FACTORY” CRUISE CONTROL.
TILT COLUMN
REMOTE, SPORT MIRRORS
POSI REAR
BLACKOUT TRIM
POWER WINDOWS / POWER LOCKS
ENGINE:
NEW GM “109” SG1 FACTORY REPLACEMENT SHORT BLOCK
STOCK RECONDIONED HEADS
NEW John Craig TA-49
NEW ADJUSTABLE WASTEGATE ACCTUATOR
HAS ELBOW FOR FENDER DUMP, (DUMP WITH ELECTRIC CUTOUT, CURRENTLY NOT ON THE CAR)
NEW AC-DELCO WASTEGATE VACUME HARNESS
NEW HEAVY DUTY INTERCOOLER COUPLNKS & STAINLESS CLAMPS
REFINISHED HEADERS / DOWNPIPE
NEW AC-DELCO DOWNPIPE EXHAUST GASKET
NEW 009 42.5lb INJECTORS
NEW ACCUFAB ADJUSTABLE FUEL PRESSURE REGULATOR
NEW BILLET VACUME POD W/TAP FOR VACUME BRAKE CONVERSION
NEW WALBORO 340 INTANK FUEL PUMP
NEW CUSTOM FUEL PUMP HOTWIRE KIT
NEW HIGH PERFORMANCE SPARK PLUG WIRES (KIRBANS)
NEW AC-DELCO CTS-43 SPARK PLUGS
NEW AC-DELCO COOLANT HOSES (ALL)
NEW AC-DELCO INTAKE VALVE SEALS
NEW AC-DELCO MINI HIGH TORQUE STARTER
NEW AC-DELCO BATTERY
NEW AC-DELCO INTAKE GASKET
NEW AC-DELCO COILPACK & IGNITION MODULE
NEW HIGH FLOW RADIATOR CORE W/RECONDITIONED STOCK END TANKS
NEW FELPRO (RUBBER) VALVECOVER GASKETS
NEW FELPRO FRONTCOVER GASKETS (NEOPREME)
NEW HIGH VOLUME OIL PUMP
NEW TIMING CHAIN / GEARS
NEW AC-DELCO TIMING CHAIN TENSIONER & SPRING
NEW AC-DELCO WATERPUMP
NEW CAM BUTTON (ATR NEEDLE BEARING)
NEW AC-DELCO CAM SENSOR
NEW AC-DELCO EGR SILONIDE
NEW AC-DELCO EGR VALVE
NEW AC-DELCO PLENUM, THROTTLEBODY GASKETS
NEW BILLET ALLUMINUM THERMOSTAT HOUSING & 160 DEGREE STAT.
NEW AC-DELCO OIL COOLER LINES
NEW RJC POWER PLATE
NEW K&N AIR FILTER
NEW FUEL FILTER (AC-DELCO)
NEW ORIGINAL GM, AC-DELCO HOOD LINER
NEW WASHER & COOLANT BOTTLES
FIRE WALL WEATHERSTRIPPING
CHROME MASS AIR PIPE
CHROME UP-PIPE
NEW AC-DELCO MOTOR MOUNTS
NEW ENGINE TOURQE STRAP
MINT INTERCOOLER AND SCOOP OUT OF A 5,000 MILE CAR
NEW SENSORS:
TPS, IAC, OXY, MAF, MAT, KNOCK, CRANK, AND OTHER MISC. SENSORS
BIGGY OIL FILTER CONVERSION (AC DELCO PF-24 FILTER)
TRANSMISSION:
REBUILT BRF - 200 R4
HEAVY DUTY 2600 STALL TORQUE CONVERTER
NEW TCC SILONIDE
700R4 FILTER & NEW DEEP ART CARR ALLUMINUM TRANS. PAN.
NEW TRANS COOLER (B&M SUPERCOOLER)
NEW AC-DELCO TRANS MOUNT
NEW TRANS COOLER LINES
REAR:
ORIGINAL 8.5” GM LIMITED SLIP, POSI REAR W/3.42 GEARS
NEW AXLES,BEARINGS, & SEALS.
NEW (KIRBANS) REAR VARIABLE WEIGHT SPRINGS
NEW REAR MONROE SHOCKS
FRESH REAR GEAR OIL CHANGE W/ADDITIVE
FRONT SUSPENSION:
NEW MOOG UPPER AND LOWER CONTROL ARM BUSHINGS
NEW MOOG BALL JOINTS UPPER & LOWER
NEW MOOG IDLER ARMS
NEW MOOG CENTERLINK
NEW MOOG INER & OUTER TIE ROD ENDS
NEW MOOG TIE ROD ADJUSTING SLEVES
NEW MONROE SHOCKS.
NEW MONROE SPRINGS
NEW MOOG SWAYBAR END LINKS
NEW POLY SWAYBAR FRAME BUSHINGS
NEW INNER & OUTER WHEEL BEARINGS & SEALS
CHASSIS/FRAME:
NEW ENERGY SUSPENSION POLYURETANE UPPER & LOWER BODY BUSHINGS (GNX BUSHINGS ADDED)
NEW FRAME BRACES - CROSSMEMBER TO FRAME, FRONT FRAME CROSS BRACE, CORE SUPPORT TO FENDER BRACES, REAR SEAT BRACES. REFINISHED GAS TANK
FRAME / UPPER & LOWER A-ARMS / REAR END HOUSING / FLOOR PAN (INSIDE AND OUT) - ALL SANDED
AND COATED WITH 2 COATS OF EASTWOODS (MAT BLACK) RUST ENCAPSELATOR TO PROTECT FROM THE
ELEMENTS.
BREAKS:
COMPLETE NEW BREAK SYSTEM FRONT TO REAR. MASTER
CYLINDER,BOOSTER,LINES,CALIPERS,P-VALVE,ROTORS,DRUMS,ETC...
WHEELS:
REFINSHED SET OF (4) FACTORY T-TYPE WHEELS. REFINISHED BY ME WITH POLISHED SPOKES AND
RUNNERS. (SHOW QUALITY)
ALL NEW TIRES
EXHAUST:
NEW 2 ½” HOOKER DUAL CAT. BACK ALLUMINIZED EXHAUST WITH AREO CHAMBER MUFFLERS. &
ALLUMINIZED TEST PIPE
INTERIOR:
NEW HEADLINER, & CARPET.
SUN VISORS RECOVERED
CONCERT SOUND ADDED
FRONT SEAT REAPOLSTERED
LOTECK 3 GUAGE POD
NEW AUTOMETER SPORT COMP. ELECTRICAL OIL PRESSURE, COOLANT TEMP GUAGES. MECANICAL 30lb
VACUME/BOOST GUAGE
STEADFAST STEERING COLUM GUARD
ALL TRIM, BACK SEAT PROFESIONALLY CLEANED / REFINISHED
ENGRAVED POWER 6 DOOR PANEL SCREW COVERS
ALL NEW GM WEATHERSTRIPPING UPPER & LOWER DOORS.
CD PLAYER ADDED
EXTERIOR:
NEW FIBERGLASS BUMPER FILLERS
NEW FIBERGLASS STICK ON FACTORY LOOK ALIKE SPOILER ADDED
REAR CHROME BUMPER - BUFFED/POLISHED
ALL NEW GM EMBLEMS
FACTORY METAL DOOR EGDE GUARDS ADDED
REFINISHED 86 T-TYPE GRILL & EMBLEM
NEW HEADLIGHT BEZZELS
NEW FRONT & REAR BUMPER RUB STRIPS
NEW HEADLIGHTS / HIGH BEAMS
NEW PARKING LAMP BULBS / TURN SIGNALS / BRAKE LIGHTS / REVERSE LIGHTS
NEW CHROME FRONT BUMPER
NEW WINDSHEILD
2 SPARE T-TYPE WHEELS
TRUNK:
IMM AUTO SPECIALTIES TRUNK KIT (BLACK) WITH “T-TYPE INTERCOOLED” EMBROIDERED ABOVE THE
SPARE TIRE COVER
NEW TRUNK WEATHERSTRIP SEAL.
LITERATURE THAT GOES WITH THE CAR:
Entire 86 dealer album.
Also all of Kirbans books.
THE CAR IS LOCATED IN LOWER DELAWARE (MILFORD AREA)
SERIOUS INQUIRY'S ONLY PLEASE.
Seller: John Burke
E-mail: HAGAR06@AOL.COM
Phone: (302) 270-8321 Cell (Leave a message if no answer)
CLICK HERE FOR PICS AND MORE INFO ON THE CAR..
THIS IS A TURN KEY CAR THAT NEEDS NOTHING BUT A GOOD HOME, IF I HAD THE CASH I WOULD BUY IT BACK IN A SECOND.
***PLEASE DO NOT POST A REPLY. CALL HIM DIRECTLY AND OR E-MAIL***
TELL HIM YOU SAW HE POST ED SINGLETON MADE ON THE CAR. THANK YOU.
POWER ANTENNA
MAP READING LAMPS
TILT COLUMN
POSI REAR
BLACKOUT TRIM
ENGINE:
NEW RJC POWER PLATE
NEW K&N AIR FILTER
CHROME UP-PIPE
NEW SENSORS:
TRANSMISSION:
NEW TCC SILONIDE
REAR:
FRONT SUSPENSION:
NEW MOOG IDLER ARMS
NEW MOOG CENTERLINK
NEW MONROE SHOCKS.
NEW MONROE SPRINGS
CHASSIS/FRAME:
ELEMENTS.
BREAKS:
WHEELS:
ALL NEW TIRES
EXHAUST:
INTERIOR:
CONCERT SOUND ADDED
LOTECK 3 GUAGE POD
VACUME/BOOST GUAGE
CD PLAYER ADDED
EXTERIOR:
ALL NEW GM EMBLEMS
NEW WINDSHEILD
TRUNK:
SPARE TIRE COVER
Seller: John Burke
