Just a general question: Do I need to put grease in the spindle cup and/or do I need to grease the bearing on the hub assembly? It spins by hand right now and didn't know if the oil in the bearing is good enough? I have attached some pics to show you what I'm dealing with. Also seems like I am missing something because you can see an opening in the center of the hub when it is attached to the spindle, and you can see all the way into the cup. Is this normal? Or do I just bolt these on and forget about them? Thanks.
