Ok the motor is back together and i found a peice that i didn't put in , it go's on the crank in the middle of the crank gear and the damper it looks like a round disc like a bowl shape . What is this i put a bigger timing chain on from comp cams i'll have to pull the frount cover to get it back in, what does this disc do and do i really need it i've never seen one before in a motor. One more i cant get the rope seal in the cover real good is there a easy way to do this.
thanks guys, your not good tell you forget things
