Lil Truck
I spend to much time here....
- Sep 26, 2002
End play on the crank is?
Chuck,
Last fall I replaced stock HGs that were leaking coolant under boost. I did some reading about coolant damaging bearings and even though I did not have any visible coolant in the oil I decided to inspect & replace all the bearings just 1000 miles ago. The thrust on the old bearings were good, and I did cut open the filter and inspect the oil for metal flakes all looked good. Oil pressure is 22 hot.
Checked the crank sensor last night, it was tight and clean.
