Pulled the pan and a couple mains/rods off Friday and found that the crank is turned 40/40... ![Frown :( :(](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
Now I get to decide what to do. I pulled the caps to see what the bearings looked like after the cam went flat. Bearings look fine, a couple have some very minor scratches, but nothing that a fingernail hangs up on, just that are visible.
I have two options facing me at this point:
1) Pull motor, find different crank, finish getting roller stuff and girdle/billet main it. Only downside, car won't be together until likely next year.
2) Get new flat tappet cam, stick it in, and start saving/collecting parts. Next winter tear motor out and do option 1. If I go this route, naturally, the car will have an easy summer with low boost only.
The motor always held great oil pressure(20 hot/idle, 50-60 on freeway and 80+ @ wot), but knowing the crank's been turned this much is making me kind of leary about putting it back together only to have something break and cause a big problem...
Would having that much material taken off take enough away from the strength of it to worry about just gently using it?
Thanks for any insight guys!
Jon
Jon
