Went to do a fuel pump install today on my car.One thing is the car had an external with seperate feed going up to the rail.Pulled the interior out and found the power wire was taped off So fuel was probly ussing that pump and extra line as a return to the tank
Pulled the tank down and found the external pump feed going directly into the sump,no filter anywhere in the system
The pump setup was a dual pump?No markings on the pumps and they looked fairly old.Both pumps were fed off the same stock power feed
So I just cut those and the external pump out and installed a 340 and ran the feed wires out of the tank and hard wired into the harness to bypass the internal connection.
Did these cars come with 2 intank pumps?It looked very good.
