dank GN
BlackArts Automotive (661)993-8277
- Jan 11, 2009
SignUp Now!restricted or lost boost signal to regulator (plugged or broken vacuum line),Bad pump,restriction (dirty filter), low voltage (check when at boost),or bad regulator.what could cause this?
I just did a braded -6 return line to accomadate the Raxtronix 340lph pump not difficult to do....All the fittings and braided line ran me 100 bucks. Wish I would have done the feed line also....The pump performs well and I can turn down the pressure at the regulator at idle which was my reason for doing the return line....I'm dropping the tank this weekend . My voltage should be 13volts due to the Hotwire . I hope it's something small . How hard is it to replace the fuel lines with AN -6 and -8 lines ? How much does it cost ? What FP should I go with if I need a replacement ?
Have any idea what it costs??? Just curious to see what it is compared to what I have in mine.....Racetronix just released a complete line kit
Zack
I believe it was 299. Go to the Vendor section. He posted it in all his pump posts.Have any idea what it costs??? Just curious to see what it is compared to what I have in mine.....
