FP Gauge - Would this make sense?
Paul Clark
Would it be possible to make a rail-mounted FP gauge that still had the Schrader (sp?) valve installed?
Maybe a push button that would dis-engage the valve when you wanted to read the FP??
Please forgive if I'm just having another dumb-attack.
Paul
if your gauge is connected using the tee that kirban sells you dont need to remove the shrader valve from the rail.
if you use that Tee and get the gauge that is on a 36" braided hose like sold by johns performance you can just lay it on the driverfender (or tie it there) so its less prone to engine vibration damage and easily veiwed under hood for tuning or swing it up under the wiper for on the road testing
