SignUp Now!My Autometer electric gage seems to be pretty accurate plus you can use the output of the sending unit to plug into Powerlogger for fuel pressure data logging.![]()
With the Autometer electrical fuel gauge, where does the sender go? On the end of the fuel rail? Is an adapter required?
I have had fuel gauges for years on diesels mounted in-cab...I did have to refill the isolator line once (it uses antifreeze) between the gauge and isolator. Seems to be very accurate.
+2...I mount the sender on the fender via a braided line from fuel rail.
Any tips for filling the line with antifreeze to the isolator? I have had trouble with air in the line and no reading on the gage.
i'm on my 4th....the supplier has to stop giving me free senders:biggrin:..lolMy electric sender is remote mounted with braided line.
