salvageV6
Daily Driver
- May 25, 2001
Follow the return line down from the regulator under the power steering pump where it goes from rubber to metal. It can get gunked up there as mentioned, and is a good one to widen out with the awl.
It uses the same fuel line O-rings and if you can get the lines separated is an easy first test.
If you jack the car up for access it's not too bad to get at, use safety jacks too, we don't want to have to repeat ourselves for a new guy.
