My Bml were at 150 so i started replacing vacuum lines one by one. With all the hoses off the vacuum block and the lines all capped. My blms get to to 136,137,138 area, I connected the PVC line blm stayed to same. then I connected to map line again BLM the same. I connect the FPR line and BLM shoot to 150. When I pull the line back off the FPR they come back down in the high 130s.
The car is 100% stock.
TPS is .40 at idle
IAC is 17 at idle.
FP line off at 39-40
FP line on at 30.
TPS is .40 at idle
IAC is 17 at idle.
FP line on at 30.
