Mile Hi GN
- May 23, 2001
Flattened the 2 and 3 mains yesterday at the track. Caught it early, shut it off and had it towed in. Crank looks good, rods fine, should have the bullet back at the track in no time. Bone stock oiling and bottom end on the motor.
The motor had 4 years, 6,600 miles, and 51 full boogie 1/4 mile passes. Car is meticulously maintained and tuned. To my knowledge the car has never seen more than 3 degrees of retard in 3rd gear at the track. I'm the first guy to lift if the numbers don't look good down at the big end.
However, I leave the street tire, street fuel thing for the little boys and their Mustangs and Camaro's. When I'm at the track each pass has the same goal - a new all time best. I walk up the air and fuel until I tickle the knock sensor for that given day. It let go on a 25 PSI, 24 degrees of advance run. Shift points were at 5,200 with 5,200 RPM's showing in the traps. Pure 118 fuel, retard was 1.6 degrees at 81 MPH fading to 0 at 90 MPH.
My opinion is this is the nature of the game. These things don't last forever and if you are going to race them they are going to break. Breakage is as much a part of the car game as tires are. If you can't stand breakage - then collect stamps.
My trusted buddies have a different opinion - they suggest that despite the 1/4 mile passes a well tuned and maintained stock block should not of failed.
What is your opinion?
