Frame Help?
nash421
Does any1 have a good formula to stiffen the chassis on a T-top 86 gn. Heard it doesnt take too much power to twist the frame... thanks
Do you have bracing behind back seat. That will help. also the missing gnx bushing.
Cheap and dirty is to weld some 2" leg .188" wall steel angle iron along the frame under the door on the inside, lip facing up of course, trim it a bit for clearance as required, it does amazing things for stiffening the frame, jack and level the car first, I prefer heavy screw jacks to really zero it in, look at nose drop and make sure doors operate very freely, then mig it all up. Get that done and I will give you the next step.
