Jul 24, 2009 #1 G galoush HWY2HELL Joined Sep 22, 2001 Messages 1,304 Guys what did you use to Notch frame regarding cutting the section out , Plasma , torch , cutoff wheels .........just wondering whats the easiest way to go about this . Thanks
Jul 24, 2009 #2 C charlief1 RIP Charlie! Joined Sep 20, 2007 Messages 23,936 http://www.turbobuick.com/forums/fa...tion/275197-rear-frame-rail-notching-how.html
Jul 24, 2009 #3 G gbodygmachine Member Joined Nov 28, 2006 Messages 229 I used a cut off wheel. Took a while, but you dont have to grind the edge like you would if you were to use a plazma cutter. JEff
Jul 24, 2009 #4 G galoush HWY2HELL Joined Sep 22, 2001 Messages 1,304 thanks guys ...........got alot of good pics to guide what im doing
Jul 25, 2009 #5 S SS_Sean Pro Bracket Joined Jul 10, 2006 Messages 5,146 gbodygmachine said: I used a cut off wheel. Took a while, but you dont have to grind the edge like you would if you were to use a plazma cutter. JEff Click to expand... +1. I used a plasma cutter and it was took a lot of work to the the edge smoothed down. next one will be with a cut-off wheel...
Aug 5, 2009 #7 H Hot Air E85 and S.E./Carolinas Moderator Staff member Joined Nov 11, 2002 Messages 3,102 Notching is the easy part. What do you do to regain the strength of the frame that is lost in the notching process? Hot Air
