Sam Colalillo
low 9's w/ a 109
- Jan 12, 2005
Need some guidance on this subject. I have a roller I purchased about a year ago that I'm restoring to a show car condition.
I have the entire front end removed, i.e. suspension, fenders, hood, etc. I have recently removed all the oiled junk on the front portion of the frame and painted it with Eastwood's Chassis Black. Look's nice! Can't believe how much piled up oil and mud can accumalate through the years.![]()
Anyway, I want to continue to paint the rest of the frame and at the same time change out the bushings. My question, if I remove all the seats, carpet, etc. from inside, can I easily lift up the body from underneath using 4x2's? If so, should I position the lumber from right to left or front to rear on each side? Which would be best?
I don't plan on sliding the frame out as I will be cleaning and painting it where it stands. At the same time I want to remove the fuel lines so I can paint them or chrome them. Not sure yet.
Another question, if I do go with lifting the body off the frame, what measurements do I need to take to make sure when I attached the body back to the frame it's lined up evenly?
Appreciate your opinions/thoughts!![]()
Dannyo
I would use 4x4's to hold it up once you get it off the frame. It should go much easier for you considering you have the front clip off. Place some 2x4's parralell to the frame under the cars floor boards and lift it gently up. Then slide the 4x4's peprpindicular to the frame rails inbetween the frame and body. This should put it up high enough for what you want to do.
As far as aligning the body onto the chasis. I just lowered mine down and set the rear wheel opening evenly in relation ship to the centerline of the rear axle.
Good luck with your project.
Sam
