My 59 Turbobugeye project has hit a speedbump. The engine is running great and the torque/speed is awesome (actually a little frightening).
I'm on my third attempt to stop a persistent rear main seal oil leak in the recently rebuilt 83 turbo engine. My first attempt was made using just RTV in the side grooves (Charlie's approach) with the engine on a stand. I let it sit two weeks before installing and another before I got it fired up. It leaked like Niagra Falls. I pulled the pan and cap and checked for problems. The RTV was sealed good on top but still uncured in the center of the cap groove and oil just blew by. It looked like it just came out of the tube!! How do you make sure this RTV cures?![Confused :confused: :confused:](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
I plan on following the procedure provided to Freddie via the subject thread.
Like Freddie, I noticed significant crankcase pressure (whistling from the dip stick tube). I stuck in a PCV and vented oil fill and ran them to unused inlets on the front of the carb. Didn't seem to impact vacuum. Does that sound legitimate? What is the normal vacuum source for the PCV?
Also, since a newly rebuilt engine is going to have significant blow-by until the rings seal, I'm thinking I may have significant leakage even if the rear main cap is sealed properly. Any idea how long it takes for rings to wear-in using break-in oil?
As always, thanks for the help.:biggrin:
