free wheel play at tilt section of steering column
DGC
Senior Member
trying to take free play out of steering wheel. following the link
down to removing the 3 torx screws under the turn signal plate.
at this point the instructions claim that the central plastic hub can
be pulled out. mine will not pull out. restriction is not from wires,
but is solid enough to indicate something else needs to be released.
the assembly under the three torx bolts moves ~1/16 of an inch in
rotation, but no movement up the column.
found another u-tube post showing these steps as well.
any suggestions are appreciated
thanks
dgc
That is annoying isn't it. After about 23 years mine was doing the same thing. Would of had to buy a couple of tools so had a trusted guy who has done many of them do it for $75. That's the only thing anyone else has touched on it other than the PM rebuild.
