streetwavesauto
- May 25, 2004
Freshly Rebuilt Short Block - Asking - $3000.00
Up for sale is my freshly rebuilt short block that has had a lot of time and money into it. I changed direction with my project and am selling it to make some more room in my garage. Here are the details on the block
Crank has been Index Ground by Lunati to 10/10 and plasma coated (prior to HOLLY Ownership), Stock Rods Center on Center with Bushed Small end and full floating pin, Stock Rods polished and beamed, Block was line bored and zero decked, King Bearings throughout, Lifter bores have been trued, .20 over JE Pistons, Billet Main Caps, Bottom end studded with ARP Bolts.
With stock iron heads block will have 9:1 compression. Should easily support 600-700hp
2. Weld Wheels - Asking - $750.00
Front Wheels - Draglites - Skinnies. I believe these are either a 15x3 or 15x4 wheel. They currently have MT ET Fronts 26.0/4.5-15 on them. Includes wheels, tires, lugnuts, center caps. The center caps are from a
set of Crager wheels. I do not have the Weld centercaps for these wheels. The lugnut holes that are not being used are filled in with red plugs. The wheels and tires are in very good used condition.
Rear Wheels - Draglites. These are 15x8 with 3.5" offset. The wheels have MT ET Drags 28.0/10.5-15s installed on them. The tires have about 20-30 passes on them and are still in very good usable condition. Includes
wheels, tires, lugnuts, center caps. I do have the Weld centercaps for these wheels. The lugnut holes that are not being used are filled in with red plugs. The wheels and tires are in very good used condition.
3. ATR Knock-Off Headers - Asking - $200.00
Up for sale is a set of brand new in the box ATR Knock-Off Headers. This package includes a drives and passenger side header, crossover pipe and all of the mounting clamps to install these on your Buick.
4. Black Painted Intake Manifold and Plenum - Asking - $150.00
Stock intake manifold and plenum – both painted black. Intake is in very good condition. None of the holes are stripped.
Thanks,
Scott
Thanks,
Scott
