Fresh Stage 2 Engine
turbodave231
Moderator
A new engine project is in the works which makes this engine available for sale. There are pictures available in the link listed below.
This engine is ready to drop in and run. It has no more than 25 passes total.
Almost every part was new when the engine was built, no expense spared. Complete build records available.
This engine powered my 3200# GN to 9.94 on a conservative 22-23 psi.
You can hear this engine run before purchase. I will NOT part this engine out, so don't ask!!
Stage 2 Engine 270 CID
New 2500016 4.1 Stage 2 offcenter block #2 cylinder sleeved (sand inclusion in bore)
Stage 2 Aluminum heads- New titanium intake valves, new Fererra SS exhaust valves, Comp Cams triple springs and titanium retainers. All new
New Moldex crankshaft - BMS forging 3.590 stroke Std/Std
Clevite V series Main and Cam brgs. Clevite H series rod bearings
Diamond Custom pistons, pins and rings- one spare piston
Carrillo 6.5 offcenter wide journal rods fresh from Carrillo
Cam Motion custom mechanical roller cam- Weber Racing timing chain
New T&D rocker arms
New Trend (Diamond) Products 3/8" pushrods
Isky offset roller lifters- fresh from Isky
JW wheel
BMS balancer
Internal Wet sump- Custom oil pan and pickup
DIS ignition system- Stock style crank sensor/cam sensor
85#/hr injectors- recently flowed and cleaned by Kinsler FI
Custom BMS FI converted 4bbl intake with rails
Meizzere Electric Water pump
Custom engine wiring harness (setup for Race only application)
Price $11,000, Sorry, I am not interested in trades.
Items Not included: Intake elbow and TB, ATR headers, 3.5 DP, T-76 Turbo, and BigStuff3. Those items may be available after the sale of the engine or included for an additional price.
Dave R
