I’m doing a little snooping in prior posts trying to find what my options are for new front brakes. I would like to just install rotors, calipers, pads, or what ever is needed and be done. I’m not prepared to make a large change. Can you point me to any good readings that may answer the following questions?
1) What is the minimum thickens a stock rotor can be turned to?
2) Assuming I need new rotors what can be put in place of stock that would be a plug and play and offer improvement (larger diameter)?
3) What is the best pad that does not create a bunch of brake dust and offers good stopping (I hate brake dust)?
4) Is there a caliper that is superior to stock that bolts right up and makes sense to change regardless of the condition of the stock caliper ( or needed with larger rotor)?
5) I assume I should also change brake lines while I’m at it. Can just change the short rubber line?
Thanks for any and all help.
Chad
Chad
