hi, i was just getting ready to swap a 210/215 comp roller cam in my 86 GN and hit a little snag. the flat tappet comp cam that came out had a grove machined in the front journal. however the new comp roller that's going in does not. the grove appears to feed the lifter galley.
should there be a groove machined in the front journal of the new roller?
i know that there is oil passage under the cam bearing in the 86/87 blocks. will i have sufficient oil flow with a regular cam bearing and no journal grove? should i just get a new cam bearing and go with it?
