Turbo6Justin
- Apr 16, 2004
This is a simple question and I am sure it has been answered but the search terms either give my every post ever made or nothing. Pulled the front cover tonight in order to start a cam swap. The oil pan has a rubber seal on it now. When I removed the front cover it looks like the rubber seal is stretched because as it sits now it is very lose. I know it will be a problem getting it where it was supposed to be so I think cutting it at the front of the block is the best option. The fel-pro front cover seal set I am going to use has the cork piece for the bottom of the front cover.
Is it okay to mix the cork front piece with the rubber for the rest of the oil pan? I am worried that it will mess with the spacing but the front cover is located by the dowels so that should be in the right spot.
I would rather not have to replace the complete oil pan gasket since the motor is still in the car.
