smokinttype
- Mar 5, 2002
I am in need of a Turbo Buick mechanic in central/north alabama. Does anyone know of anyone? In need of a high volume oil system put on my stock block. Thanks in advance.
Oil pressure is about 7-8psi at hot idle. I've tried different weights and gotten the same resultWhat is your oil pressure now?
What oil are you running?
How many miles?
Does the oil psi come up with rpm?Oil pressure is about 7-8psi at hot idle. I've tried different weights and gotten the same result
