OK I need a better understanding on removing the front coil springs on my 87 GN I was going to use a jack under the A frame and remove the 2 pivot bolts on the frame side . can I leave the lower ball joint alone or do I have to at lease break it loose ? Also If I leave it alone will the a arm swing down enough to get the spring out? and finally when I install the new springs do I need to compress the spring or is there enough room to slip it back in with out one ? Thanks, ED
