Monte88
- Feb 14, 2005
Selling for a friend of mine, contact me with any questions BlackmonteSS@hotmail.com:
Numbers matching 1978 Z28. Painted last year with all new decals. Supercharged 350 engine. 4spd Super-T10. 8.5" 4.10 rearend.
This is a car you can get in and drive everyday, anywhere you want, we have sat in traffic for an hour in 90 degree weather and had no overheating issues. The gearing is a little steep as you can see, but it is very happy at normal highway speeds.
Power stats
575hp/540lb-ft (pump gas)
dyno and track tested (papers inc. w/ purchase)
Car has 12 drag passes on it since being completed in July of 2006. It ran consistent mid-11's @127 mi, with 2.0 60' - granny shifting! We have all time slips to prove it. car still has much more potential.
Moves right along for a 3500lb car!
Engine stats
350 cid blueprinted - papers inc w/ purchase
steel crank
h-beam rods
forged blower pistons
gapless rings
ARP hardware
racer brown solid cam
heavily ported 993 heads (#'s heads also inc w/ purchase)
2.02/1.60 valves
roller rockers
6 qt z-28 oil pan
cometic head gaskts
SDCE P600B blower kit
ProFlo surge
13 # boost
SDCE carb hat
air filter reloc kit
spring tensioner upgrade
blower prepped holley 650 carb
Car stats
car not gutted - all steel except VFN 4" hood, factory glass, and factory back seat w/ front race seats
horn, lights, heat, e-brake work
legally inspected and registered in RI
New carpet, headliner, door panels
4 speed #'s tranny
8.5" rear 4.10's, posi
mcleod clutch
gear reduction chevy starter
walbro fuel system w/ return
comp eng front shocks
jacobs ignition
battery reloc to trunk w/ cutoff switch
long wheel studs
driveshaft loop
headers, full exhaust
VFN 4" cowl pin-on hood on car
Z-28 "tear drop" hood inc w/ purchase
mickey thompson drag radials - car hooks on the street in first gear!!!
I have dozens of photos that document the entire build of the car that I can send to anyone interested. The car's timeslips and dyno sheets will also go with it.
Asking $15,000.00 or best reasonable offer. Car MUST go!!!
Power stats
Engine stats
steel crank
h-beam rods
gapless rings
ARP hardware
2.02/1.60 valves
roller rockers
6 qt z-28 oil pan
cometic head gaskts
ProFlo surge
13 # boost
SDCE carb hat
Car stats
4 speed #'s tranny
mcleod clutch
jacobs ignition
long wheel studs
driveshaft loop
![img7668cm7.jpg](/proxy.php?image=http%3A%2F%2Fimg228.imageshack.us%2Fimg228%2F6967%2Fimg7668cm7.jpg&hash=1fabf9928d5ceebfbd1d76d6faccfe3c)
![78camaroqt2.jpg](/proxy.php?image=http%3A%2F%2Fimg228.imageshack.us%2Fimg228%2F8426%2F78camaroqt2.jpg&hash=54726459cd54f453039f0489f374e795)
![img7830lw4.jpg](/proxy.php?image=http%3A%2F%2Fimg228.imageshack.us%2Fimg228%2F7896%2Fimg7830lw4.jpg&hash=cf6d54df82300b2890353d270f7f502b)
![img7664xk7.jpg](/proxy.php?image=http%3A%2F%2Fimg228.imageshack.us%2Fimg228%2F679%2Fimg7664xk7.jpg&hash=89c0e0fe97a49cc7c31725321b5c8661)
![img7707of4.jpg](/proxy.php?image=http%3A%2F%2Fimg229.imageshack.us%2Fimg229%2F7972%2Fimg7707of4.jpg&hash=3235dbf664889b32a2f3bdfa8bb4a97e)
