TurboJoe3.8
Senior Member
- Feb 19, 2003
Bowling Green Custom 23 Row Stock Location Stretch Intercooler and Shroud. This IC is in excellent condition, has no bent fins, dents, or road rash. The IC and the shroud both have been notched to fit around the front sway bar. This is a new core, not two old stock IC cores welded together. Here is what is says about the IC on the BGC website:
"A new state of the art intercooler core called a stager core is used. It has cooling fins inside the tubes that move the air in and out for better heat transfer. Although it is 6" longer than stock, it is almost undetectable when intalled. This high tech core uses a new technology called fuse bonding which helps transfer heat more efficiently. Core has twelve fins per inch (stock is eight) and contains 23 tubes versus 17 when putting two stock units together. Also shroud is adjustable for max flow."
This thing is huge!
Do some research on the board and you'll see that some members have gone into the 10's with this IC. I bought this to upgrade from my MJ 17 row, but now have decided to go in another direction.
Price is $550.00 firm shipped to your door in the lower 48 states. This also includes the BGC fiberglass adjustable shroud.
This is a great IC for the price!
Thanks, Joe :wink:
This thing is huge!
Thanks, Joe :wink:
