FS: Large List of Parts
motorhead
motorhead mike
Here is what we have (all prices in CDN dollars, shipping extra):
Turbo Buick/Grand National Specific:
1) Complete Stock 8445 Heads (unmolested, off low mileage engine) - $100
2) Art Carr (16930) non-L/U torque converter unit rated at 3400-3600rpm - $450
3) Mease Performance Engineering 3" aluminum MAF pipe, elbow and K&N filter - $125
4) Drive shaft loop - a simple home-made unit using the factory strap and HUGE solid U-bend - $15
5) 2 x Turbo Tweak v5.6 chips for alky/propane, 83pph injectors, 3000 stall and a stock MAF - $50/pr
6) 2 x 233 Bosch FPRs - $15
7) No name brand Adjustable FPR - $30
8) Ashtray switch plate w/two momentary switches - (a BuickGN.com product?) engraved with Alky & Transbrake - $20
9) RJC-style manual boost controller - ran 23+psi on the stock WG and 27+psi with the HD WG - $30
10) Bailey Engineering BstC “Boost Controller” w/bleed solenoid - $125
Exhaust:
1) Summit Racing dual exhaust 2.5” header-back kit (P/N 680131) – NIB, complete less mufflers - $175
2) Two (2) Hedman 3”-2.5” ball flange reducers w/O2 sensor bungs (P/N 21143) – NIB - $40
Wheels:
1) Weld Drag Lites – 15x3.5” & 15x8 (w/3.5” BS) – 5x4.75 bolt circle, includes 165R15 & 275/60R15 tires, 20 lugs & washers and 2 centre caps - $850
2) 2002 Z28 Factory “Snowflakes” – four 16x8 wheels (5x4.75” bolt pattern), includes 245/50R16 GSA tires (worn) and 26x10.5 ET Streets (not mounted) and centre caps and a set of 235/50R16 Toyos Proxes - $350
3) Dyna Lite “Crosslace” (GNX style) – four 15x7 light weight 2-piece wheels (5x4.75 bolt pattern), these are currently disassembled for refinishing and will require the work to be completed and new assembly hardware (old fasteners included), rumour has it they are quite rare - $300 - I will include a set of 215/65R15 and 275/60R15 tires for $150 more.
Engines & Parts:
1) Complete TPI 305 Swap – includes - Full ECM and Chassis harnesses, 7730 ECU (Speed Density), Factory in-tank electric fuel pump and hanger assembly, Intake bellow, upper and lower air boxes and K&N drop-in filters, Dual electric fan assembly w/upper and lower brackets, Stock 1991 LB9 shortblock (rated at 9.3:1 Compression (230hp/300ft-lbs)), Fully ported upper, lower and intake runners, Factory distributor (cap, rotor and MSD Blaster coil), Ford Motorsport "19lb/hr" injectors (rated at 22.5lb/hr at 43.5psi), Holley adjustable fuel pressure regulator, Ported throttle body w/air foil & TPS, Fully ported "193" heads (specs below) w/stainless steel 1.94 intake & 1.5 exhaust valves, guide plates, screw-in studs & factory rocker arms, Full CompCams roller valvetrain w/stock TPI computer friendly cam, Hydraulic roller lifters, pushrods & matching valve springs, Factory valve covers; and Extra TPI gaskets - $1499
2) TPI Intake Set-up (MAF based) - upper and lower intakes, runners, fuel rails (no FPR), throttle body, NO hardware included - $100
3) GM Performance Parts LT4 valve springs (P/N 12495494) – NIB - $35
Transmission & Driveline Parts:
1) TransGo Low/Reverse Boost Valve (P/N 7-300) – fits THM 700R4 & 2004R and provides a firmer manual 1-2 shift, holds manual low gear longer, higher speed manual shift back to low - NIB - $10
2) SS/442 200-4R (CZF/CRF etc) Servo cover (P/N 8635692) and piston (P/N 8633563) w/spring, seals & retainer ring - $10
3) Stock GN (w/200-4R) 8.5” driveshaft - $75
Miscellaneous Electronics:
1) MSD/Vortech Universal Boost Timing Master (P/N 5462) w/Ford TFI coil adapter harness (P/N 8874) – NIB - $225
2) APEXi SAFC-II w/extended harness - $175
3) HKS Type 1 Turbo Timer (silver) - $75
Body & Mechanical Parts:
1) Stock 98-02 Camaro Z28 hood (factory black) - $100
2) 2” Cowl induction hood for ‘81-‘88 Monte Carlo (fiberglass, bolt-on, factory black) - $549
3) 1991 Z28 tail lights - one has a hardly noticeable hair line blem/crack - $40
4) 1991 Z28 Hatch Retractor/Closer/Pulldown/Automatic Latch/Power Release - complete assembly worked when removed from car - $100
5) 1991 Z28 Wiper motor - $10
Interior:
1) 1983 Monte Carlo dash plaque and gauge surround – non-SS, maroon in colour - $30
Some pictures can be found here: Index of /images/forsale ; additional pictures available upon request.
All parts are open to offers/negotiation/package deals… don’t be shy!
Email michael_lis@whitetrashdesign.ca or call 289-298-5185
NEW LIST!
5) Two (2) Turbo Tweak v5.6 chips for alky/propane, 83pph injectors, 3000 stall and a stock MAF - $50/pr
6) Two (2) 233 Bosch FPRs - $10/pr
8 ) Ashtray switch plate w/two momentary switches - (a BuickGN.com product?) engraved with Alky & Transbrake - $20
11) Billet inlet bell for stock turbo - $45
12) Stock downpipe elbow - $25
13) Stock downpipe & elbow w/gaskets & bolts - $50
14) Black Buick Tri-shield horn button insert - $15
15) Stock turbo shield cut for 3” downpipe - $35
Exhaust:
Wheels:
Engines & Parts:
Interior:
2) 1997 Z28 t-top headliner in medium grey - $10
how much on the heads shipped to 60451? I work for Canadian national railroad. Any discounts. LOL
The heads are pending sale. I'll let you know if they don't clear the deal.
I don't know if Canada post gives discounts to CN Rail employees? And I work for the Canadian Forces... want to give me a bonus? :confused: LOL! ;)
PMs returned.
As a courtesy to others and myself: if you have fallen out of interest in a part, say so.
NEW LIST:
6) Two (2) 233 Bosch FPRs & one (1) 237 Bosch FPR - $20/set
16) Direct Scan - $80
17) Powermaster – unknown condition - $50
Exhaust:
Wheels:
Engines & Parts:
4) Stock TBSS intake setup (complete w/silencer) w/K&N replacement filter - $75
2) APEXi SAFC-II w/extended harness - $175 – (PENDING)
Interior:
Some pictures can be found here: http://whitetrashdesign.ca/images/forsale ; additional pictures available upon request.
Exhaust:
Wheels:
Engines & Parts:
1) Complete TPI 305 Swap – includes- Full ECM and Chassis harnesses, 7730 ECU (Speed Density), Factory in-tank electric fuel pump and hanger assembly, Intake bellow, upper and lower air boxes and K&N drop-in filters, Dual electric fan assembly w/upper and lower brackets, Stock 1991 LB9 shortblock (rated at 9.3:1 Compression (230hp/300ft-lbs)), Fully ported upper, lower and intake runners, Factory distributor (cap, rotor and MSD Blaster coil), Ford Motorsport "19lb/hr" injectors (rated at 22.5lb/hr at 43.5psi), Holley adjustable fuel pressure regulator, Ported throttle body w/air foil & TPS, Fully ported "193" heads (specs below) w/stainless steel 1.94 intake & 1.5 exhaust valves, guide plates, screw-in studs & factory rocker arms, Full CompCams roller valvetrain w/stock TPI computer friendly cam, Hydraulic roller lifters, pushrods & matching valve springs, Factory valve covers; and Extra TPI gaskets - $1499
Interior:
NEW LIST:
16) Direct Scan - $70
Exhaust:
Wheels:
1) Weld Drag Lites – 15x3.5” & 15x8 (w/3.5” BS) – 5x4.75 bolt circle, includes 165R15 & 275/60R15 tires, 20 lugs & washers and 2 centre caps - $849
2) 2002 Z28 Factory “Snowflakes” – four 16x8 wheels (5x4.75” bolt pattern), includes 245/50R16 GSA tires (worn) and 26x10.5 ET Streets (not mounted) and centre caps and a set of 235/50R16 Toyos Proxes - $300
4)Two (2) Cooper Cobra 215/65R15 tires in good condition – $60/pr
5)Two (2) Hercules 275/60R15 tires in good condition - $110/pr
Engines & Parts:
1) Complete TPI 305 Swap – includes - Full ECM and Chassis harnesses, 7730 ECU (Speed Density), Factory in-tank electric fuel pump and hanger assembly, Intake bellow, upper and lower air boxes and K&N drop-in filters, Dual electric fan assembly w/upper and lower brackets, Stock 1991 LB9 shortblock (rated at 9.3:1 Compression (230hp/300ft-lbs)), Fully ported upper, lower and intake runners, Factory distributor (cap, rotor and MSD Blaster coil), Ford Motorsport "19lb/hr" injectors (rated at 22.5lb/hr at 43.5psi), Holley adjustable fuel pressure regulator, Ported throttle body w/air foil & TPS, Fully ported "193" heads (specs below) w/stainless steel 1.94 intake & 1.5 exhaust valves, guide plates, screw-in studs & factory rocker arms, Full CompCams roller valvetrain w/stock TPI computer friendly cam, Hydraulic roller lifters, pushrods & matching valve springs, Factory valve covers; and Extra TPI gaskets - $1299
5) Crane Cam Gen 1 SBC (retro-style) solid roller lifters with rev kit, Gold roller rockers and stud girdles & lock nuts; used and in fair condition - $235
3) HKS Type 1 Turbo Timer (silver) - $70
1) Stock 98-02 Camaro Z28 hood (factory black) - $99
4) 1991 Z28 Hatch Retractor/Closer/Pulldown/Automatic Latch/Power Release - complete assembly worked when removed from car - $90
Interior:
More Parts ADDED!
6) Two (3) 233 Bosch FPRs & one (1) 237 Bosch FPR - $20/set
11) Billet inlet bell for stock turbo - $40
12) Stock downpipe elbow - $20
13) Stock downpipe & elbow w/gaskets & bolts/springs - $45
17) 3” Dump pipe w/4-bolt flange (bring your own cap & hardware (I never used any ;) )) - $30
18) Stock plastic vacuum block w/bolts - $15
19) Stock A/C compressor brace - $15
20) Stock ashtray - $5
21) Four (4) new Comp Cams 980 valve springs & twelve (12) stock spring cups - $15
Suspension:
1) 34mm hollow front sway bar - $40
2) G-body stock rear springs - $30/pr
Cooling:
23) Aluminum F-Body radiator (w/built in trans cooler) - $100
Exhaust:
Wheels:
Engines & Parts:
6) Center bolt valve covers (a bit grimy, minor rust spots… but sound) w/grommets and oil cap - $10
Interior:
3) B&M “T” Shifter handle (missing switch) - $15
