All prices in CDN dollars, PayPal fees set at 4%, and shipping is extra:
Turbo Buick/Grand National Specific:
3) Mease Performance Engineering 3" aluminum MAF pipe, elbow and K&N filter - $125
5) Two (2) Turbo Tweak v5.6 chips for alky/propane, 83pph injectors, 3000 stall and a stock MAF - $50/pr
6) Two (3) 233 Bosch FPRs & one (1) 237 Bosch FPR - $20/set
8 ) Ashtray switch plate w/two momentary switches - (a BuickGN.com product?) engraved with Alky & Transbrake - $20
11) Billet inlet bell for stock turbo - $40
12) Stock downpipe elbow - $20
13) Stock downpipe & elbow w/gaskets & bolts/springs - $45
17) 3” Dump pipe w/4-bolt flange (bring your own cap & hardware (I never used any
)) - $30
18 ) Stock plastic vacuum block w/bolts - $15
19) Stock A/C compressor brace (steel “Y” brace w/two holes added for MAF bracket) - $10
20) Stock ashtray - $5
21) Four (4) new Comp Cams 980 valve springs & twelve (12) stock spring cups - $15
22) WO2 (black out) front fender trim today in okay condition (DS needs a crease removed (I lost a wheel once... once)) - $30/pr
23) IAC relocation harness - $10
Suspension:
1) 34mm hollow front sway bar - $40
2) G-body stock rear springs - $30/pr
Cooling:
1) Aluminum F-Body radiator (w/built in trans cooler) - $100
2) Ford Taurus electric fan w/harness - $25
Exhaust:
2) Two (2) Hedman 3”-2.5” ball flange reducers w/O2 sensor bungs (P/N 21143) – NIB - $40
Wheels:
1) Weld Drag Lites – 15x3.5” & 15x8 (w/3.5” BS) – 5x4.75 bolt circle, includes 165R15 & 275/60R15 tires, 20 lugs & washers and 2 centre caps - $849
2) 2002 Z28 Factory “Snowflakes” – four 16x8 wheels (5x4.75” bolt pattern), includes 245/50R16 GSA tires (worn) and 26x10.5 ET Streets (not mounted) and centre caps and a set of 235/50R16 Toyos Proxes - $300
4)Two (2) Cooper Cobra 215/65R15 tires in good condition – $60/pr
5)Two (2) Hercules 275/60R15 tires in good condition - $110/pr
Engines & Parts:
1) Complete TPI 305 Swap – includes - Full ECM and Chassis harnesses, 7730 ECU (Speed Density), Factory in-tank electric fuel pump and hanger assembly, Intake bellow, upper and lower air boxes and K&N drop-in filters, Dual electric fan assembly w/upper and lower brackets, Stock 1991 LB9 shortblock (rated at 9.3:1 Compression (230hp/300ft-lbs)), Fully ported upper, lower and intake runners, Factory distributor (cap, rotor and MSD Blaster coil), Ford Motorsport "19lb/hr" injectors (rated at 22.5lb/hr at 43.5psi), Holley adjustable fuel pressure regulator, Ported throttle body w/air foil & TPS, Fully ported "193" heads (specs below) w/stainless steel 1.94 intake & 1.5 exhaust valves, guide plates, screw-in studs & factory rocker arms, Full CompCams roller valvetrain w/stock TPI computer friendly cam, Hydraulic roller lifters, pushrods & matching valve springs, Factory valve covers; and Extra TPI gaskets - $1299
3) GM Performance Parts LT4 valve springs (P/N 12495494) – NIB - $35
4) Stock TBSS intake setup (complete w/silencer) w/K&N replacement filter - $75
5) Crane Cam Gen 1 SBC (retro-style) solid roller lifters with rev kit, Gold roller rockers and stud girdles & lock nuts; used and in fair condition - $235
6) Center bolt valve covers (a bit grimy, minor rust spots… but sound) w/grommets and oil cap - $10
7)Stock 1996-00 Vortec intake manifold (has spider injector assy, & what is shown in pictures) - $25
Transmission & Driveline Parts:
2) SS/442 200-4R (CZF/CRF etc) Servo cover (P/N 8635692) and piston (P/N 8633563) w/spring, seals & retainer ring - $10
Miscellaneous Electronics:
1) MSD/Vortech Universal Boost Timing Master (P/N 5462) w/Ford TFI coil adapter harness (P/N 8874) – NIB - $225
3) HKS Type 1 Turbo Timer (silver) - $70
Body & Mechanical Parts:
1) Stock 98-02 Camaro Z28 hood (factory black) - $99
2) 2” Cowl induction hood for ‘81-‘88 Monte Carlo (fiberglass, bolt-on, factory black) - $549
3) 1991 Z28 tail lights - one has a hardly noticeable hair line blem/crack - $40
4) 1991 Z28 Hatch Retractor/Closer/Pulldown/Automatic Latch/Power Release - complete assembly worked when removed from car - $90
5) 1991 Z28 Wiper motor - $10
6) 1993-96 Camaro front license plate bracket - $5
Interior:
1) 1983 Monte Carlo dash plaque and gauge surround – non-SS, maroon in colour - $30
3) B&M “T” Shifter handle (missing switch) - $15
Some pictures can be found here:
Index of /images/forsale ; additional pictures available upon request.
All parts are open to offers/negotiation/package deals… don’t be shy!
Email
michael_lis@whitetrashdesign.ca or call 289-298-5185
