New set of (3) Auto Meter gauge angle rings for 2 1/16'' gauges $10.00 shipped
New complete set of clevite rocker arms and retainers only no shafts, for both heads 6 stamped right and 6 stamped left $35.00 shipped.
New 1 pair of front sway bar end links red polyurethane bushings $30.00 shipped.
used egr valve and plastic snap on cover $20.00 shipped.
used Kenne Bell billet adjustable fuel pressure regulator works good no problems $70.00 shipped.
used (1) 86-87 stock water pump pulley $20.00 shipped.
used (2) sets of (4) locking lugnuts for Weld Pro-Star wheels, 1 set is for 1/2''-20 wheel studs and the other set is for stock wheel studs $15.00 shipped each set.
used 1985 T-Type wheels (4) 15x7, 30 fin in good condition $150.00 i will help with shipping on these in the lower 48.
used set of (6) 72lb/hr Siemens injectors with matching extender extreme chip and modified ecm for use with both low and high impedance injectors $425.00 shipped.
used (2) egr vacuum solenoids works good $20.00 shipped.
used oil cooler adapter for 86-87 good condition $20.00 shipped.
used map sensors (2) stock 86-87 good condition $ 15.00 shipped.
NEW hood emblems (2) 3.8SFITURBO $45.00 shipped.
used (1) set of support lift hood shocks for aluminum hood $25.00 shipped.I used these on a stock steel hood and they worked fine.
shipping is to lower 48 only on all items.
Thanks, John :smile:
