Fuel Fittings at Frame
J-B Racing
Forced Induction
Does anyone know the PN for the Fittings ate th Engine Bay Fuel Lines at the Frame to convet to Braided Hoses? I think the return is989DBJWhat would be for the Pressure line??
I think Earl or Russell make them. -8 for the pressure an -6 for the return.
Thanks for the help.
Joe
Joe you will need to replace the factory return line as it is only a 1/4" and if your StageII is going to make more than 750 HP you will need to upgrade the feed line, too. Read some of my posts on the topic to see how I did just that. Pm me for my number to talk about options. Leave a message as I work long hours and can't always answer my phone when at my normal job. But I will call you back.
Hi Ken,
The return and the stock feed is just ti run the car at Idle before my 1200 HP Weldon is activated with a Hobb Switch running in a -10 Line. I would not be stupid enough to run a Stage Motor on just the stock lines. That is why I was looking for the Fittings so I can put Braided Hoses on the driver side of the Engine. Thanks for looking into this matter. I run a LT1 Pump in the Tank up to 4 psi of boost. This Motor pumped 1188 Hp at the wheel with an out dated 90 mm turbo.
Joe
I have all the fittings and 6ft of braided hose for sale. Asking 60 plus shipping.
You have both Fittings for the Fuel Lines at the Frame? But you are asking too much for shipping!!
I would be interested..
Actually, its not me... its the post office. LOL Part number I have for the saginaw fitting tho is 9894dbjerl.
