Fuel Injectors
SCD
I need an opinion on which fuel injectors I should have cleaned. I have an 87 GN with 60,000 on the clock with a leaky fuel injector. The motor is stock except for Tomco 30lb injectors, a new cam 204/194 (I wiped the #3 exhaust lobe on thestock cam), adj fuel regulator,hot wired HP fuel pump,and a Casper Ultra chip.
I did some checking and have a leaky fuel injector. The crankcase is filling with gas.
I have the original Bosch injectors and I am wondering if I should have these rebuilt instead of the Tomcos.
When I installed the Tomcos the car never seemed right.
Steve
I just sent you email. I have a set of 33s for sale if you're interested.
The tomco injectors have only 3,000 on them and the chip was burned for them.
Just so you know, I used a Reds93 for stock injectors with the 33lbs injectors and they worked fine and even passed emissions.
