Fuel Line Upgrade
USMC_Turbo6
Good Morning Gentlemen,
Here is the plan I will be removing all of the fuel line and want to upgrade it all. I know that I will have to run a -8 and -6 line to and from the pump. I want to know what more I will I need other than the fitting. Do I need to add two inline fuel filters, will it work with the stock hanger and what more will I need to do? Can someone show me some pic of how they did there fuel line upgrade.
Keep your stock lines. They are capable of 10.00. We removed all the Saginaw fittings to improve flow in both supply and return. Pretty simple to do. Unless you plan on running fater than 9.70's I wouldn't use braided stainless. There is a HUGE cost in doing that. If you need help PM me and I'll give you my number and I can explain what works and what is a waste. Been doin' this for 25 years. Sounds like your combo is block limited, anyway. If you step up to StageII, (or TA) then we can discuss what needs to be improved.
I had a -8 line on my car for a while and ended up removing it. It just isn't necessary and like said above, an expense you can do without when you are using 60 lb injectors.
