For thos of you who read and helped on my last thread, here is what I have done so far and still can't get to start.
I took the fuel tank off, cleaned it out completely. Checked my fuel pump to see if it works (it does), changed the fuel filter, and replaced a cracked hose. I put everything back together and put 5gal of premium in it.
On the electrical, I replaced all the plugs (getting spark), cleaned all the posts on the coil pack, and made sure all the plugs are plugged in and vacuum hoses are correct...still no start. It will only fire with starter fluid.
I took the valve out of the schrader valve and put a clear hose to it, it had a little bit of old yellow gas in it. I took the fuel pump test wire and ran it straight to the battery and can hear the pump turn on....but nothing comes out of the schrader?????
Does this mean that my lines are clogged...or maybe not enough voltage getting the pump to run fast enough?
