Remember, you have to pump 30% more fuel with E85 to get the same horsepower, so your stock lines are already pushing 30% more fuel which requires more pressure which pushes your pumps even more. Also, as fuel flow goes up, the pump produces LESS pressure so the pump is being pushed big time! Bigger lines help that situation by reducing the pressure drop in the feed and return lines! FWIW, you cannot look at just one component in the fuel system (supply and return lines, fuel logs, fuel pump, fuel pressure regulator, injectors, filters and all the fittings), you have to look at it all since it is strong as the weakest component. Yes, your buddy may appear to be getting away with something but that doesn't mean you can or will. No two fuel systems and motors are ever exactly the same!
Conrad
