Like I said,you need more voltage. your generator is falling of way more than it should so you need to fix the one you have or replace it. When you get a generator that produces power like it should and doesn't fall off,it might be enough to solve your problem,but you'll still be on the edge with fuel delivery. More amps does nothing for you. You need more voltage. I would get a stock replacement. I actually prefer to find a good one in the junk yard,but an AC Delco reman will do. I recommend that you call Quad Air and order their volt booster. Your fuel pump and ignition system will love it.
No,you don't need bigger lines. I'm making 700 plus horsepower on E 85. that means I'm moving about the equivalent amount of fuel through the stock lines as a 1,000 hp motor on gasoline. Red Armstrong is trapping at 150 mph and he has the stock lines. When you're making much more power than you are now,you could drill out the four areas on the fuel supply line where the O-rings are to .299". You're a long way from needing to do that.I've watched many people needlessly butcher their stock lines .
I just bought a Powermaster 200amp with adjustable voltage regulator. Going to set it at 14.5v and hopefully it will fix that issue.
I know the extra amps wont do anything for the voltage but my Nav/Stereo system will like it.
