TurboTdr3.8
- Jan 15, 2013
How long does the fuel pressure hold after you cut the car off , other than injectors leaking what would cause fuel pressure to bleed off , mine stays up for maybe 10 minutes or so and then it goes slowly to zero , Does this sound normal . It primes back up when restarting and starts perfect , I checked my old fpr under vacuum and pressure against a new one and they do the same readings . BTW I have found no leaks in the line or hoses either . It this a sign of a weak fuel pump or relieve valve ? Or should I not worry about it .
