Hello. Now that I have time to drive this thing all sorts of mechanical questions now. Been running fine and today I went to start the car about an hour after running fine and I had a no start. It cranked but didnt turn over. The fuel pump was making its normal noise with ignition in the on position. When I checked my Fuel pressure at the schrader valve it was below 20 psi. Typically it didnt move from its 42 psi its set at when off. I cranked up the fuel pressure to 55 psi and it turned over right away. I reset the FP back to 42 psi and its been fine the rest of the day. I have a new AFP Regularor and new injectors. What could have caused this? Filter? Thanks
