Fuel pressure question
xtremexnyc
My fuel system consists of a Hot wired 340 fuel pump, Lucas 009 injectors. My chip is a reds 93 setup for the 009's. Whats the suggested fuel pressure i should run with this setup? Also my turbo is a TE-44 with an ESP FM. My boost is set at about 17 to 18 psi. Fuel pressure was set by my mechanic at 38 vac line off. Right now my scan master is acting up so i do not have it connected.What do you guys suggest.
For the street 38-42 line off is ok, all cars are different. For racing start at 50 line off and work up and down in 2psi increments until your car runs the best:D Frank
