I am in the process of re-installing the engine on the GN. It has a BGC intake with the AL rails that came with the intake. It has an Accufab regulator and the old o-ring going into the rail tore. I picked up a variety pack of Viton o-rings and couldn't get it to seal. I have seen threads on here about folks having issues getting the right o-ring and getting it to seal. The one thread I read seemed to indicate the o-ring from NAPA worked while the o-ring form O'Rielley's did not.
I had seen some threads about modifying the fuel system and relocating the regulator, but the links in the threads generate a forum error.
If I can't get the correct o-ring or have more issues I was just going to look at making a plug and plugging the rail, or tapping and plugging the existing regulator hole in the rail and moving the regulator to the end of the rail which is already set up for NPT. It looks like on the Accufab regulator you can unscrew the fitting that goes into the rail and replace it.
