DarthBuick
I Win even in your dreams.
- Dec 22, 2014
I noticed my car started running lean at WOT. I moved my FP gauge to windshield and it never got over 46 PSI. So I started to test the FPR and pressure barely changed when I removed the vacuum line. So while it was idling I tried to blow 8 PSI of regulated air into the Vacuum port to see if pressure would rise and I saw a small amount of fuel come out of the Vacuum port. I am guessing this is the reason pressure wont rise under boost.
It is a standard blue Kenne Bell regulator and I was wondering if someone has a part number for a new diaphragm or repair kit. Thanks
