white-t-type
- Oct 13, 2008
When my car is running with the vacuum line on or off the fuel pressure stays at 52lbs. I have an accufab fuel pressure regulator, when I back the srew out of the top the fuel pressure does not drop. Also thought I would mention that it does not change even when you put the vacuum line back on. Any ideas? Also thought I would throw in the lowest reading I can get on my TPS is 4.69. Car is definately running rich. I took it for a short drive and the plugs are completely black, o2 volts were in the high 500 to low 600's at idle and in the upper 700's at normal driving. Giving the car more than half throttle results in fouled plugs. Just looking for some ideas.
