SignUp Now!Just checked fp. Got 34 line on 38 line off and 55/56 at WOT with 16.5lbs of boost. Seems low correct in thinking 38 line on 42 line off and roughly 60 at WOT?
Galaxy S7 Edge
I would, better to be safe. I don't know what fuel you are using, (assume 91) but you're probably pushing the limits of it right now. See what you can do after the chip and injector swap.... get a boost controller so you can move up in slow increments.I'll try changing the springs in the wastegate to give me 13.5lbs instead of 16lbs.
Galaxy S7 Edge
Ok, we have 93 here in the Kansas City area as well, can't understand why it would be detonating.Going to crank up fp after injector and chip install. Gas here in jersey is 93 octane
Galaxy S7 Edge
Good deal! Timing may have been too aggressive with the old setup.Well swapped out injectors and installed tt chip, also dropped boost down from 16.5/17 to a clean 15 and I'm getting o2's in the high 700's and no knock. Although I am getting a major tapping noise but I know that it from the egr I reinstalled with the busted gasket, that will get fixed tomorrow.
Galaxy S7 Edge
why don't you put more infomation than 87 turbo regal so someone can tell you what to do? johnDidn't start the tapping till after I installed the injectors. When I took the egr valve off the gasket stayed whole but was brittle as hell, I'm thinking this is my tapping noise but will find out tomorrow when I replace the gasket.
Galaxy S7 Edge
