jason walker
- Jul 1, 2012
I noticed my car would not start last week till it turned over for about 20 seconds acted like it was out of gas but after it started it was fine ran ok . but if I let it set for 30 minutes or more it would do the same thing hard to start but if I turned it off and then restarted it was fine in other words it would crank right back had set my fuel pressure to 42psi originally checked my fuel pressure and it was @ 25 psi  so I thought try to turn it up so loosened locking nut on fuel pressure regulator and screwed in adjustment screw pressure would not rise at all . what could be my problem I installed new fuel pump last year it is a DEATSCHWERKS 301-S ... Any ideas ? tried one more time  turned on switch heard now fuel pump looked at fuel pressure gauge it was @ 20 or 22 psi
