Jesse Whitley
- Apr 19, 2012
Sorry this is a total NOOB question but im not sure about domestics and the fine tuning of things since I came from the import seen where stuff is a bit different. I know my injectors and fuel pump arent stock, not sure size im sure i could pull one off if needed to check. I live in Albuquerque where its about 6500ft above sea level. What is a good fuel pressure to run. My car seems to run rich but my car wont run if i raise my FP above 30psi. It runs best in the low 20s but im not about to blow my motor up hints the Dumb questions. I know things need to be leaner at this altitude but it just seems to low. Im also runing a caspers chip and any help would be appreciated
87 Buick GN
Mods: Precision TE44 turbo, Larger injectors, FP, FPR, Down pipe with electronic cut out, caspers chip, Built T-350 tranny, upgraded intercooler, K&N intake, upgraded hardpipes, and other suspention and sway bar stuff
87 Buick GN
