SignUp Now!I saw you ask this a couple times.... the answer is no, you do not have to turn it up for the track. What happens is, for every psi of boost, the fuel pressure will rise by one psi. So basically, the FPR will regualte this itself. If you set the FP to a normal setting (let's say 45psi, line off), then when you put the vacuum line on, it will be around 39psi FP. When you are accelerating just enough to not make boost, then you'll be at 45psi FP. If you boost to 15psi, then the FP will be (line off pressure + amount of boost) 60psi.Originally posted by mike
I'm gonna mess with it today. But when I go to the track, should I turn it back up?
Originally posted by Chuck Leeper
I test alot of the rail mtd "inexpensive" ga.'s NOT 1 IS CLOSE to the certified ga. on my fuel injector test bench.
