Fuel Problems????????
87we410877
I had the car out yesterday and it was running fine. Today i went to start it and it wants to start but doesnt. It smokes alot out the exhaust and also spits visible fuel on the ground out the exhaust. When i do play with the gas, it will run but as if only on 2 cylinders. Fuel pressure is slightly higher and the digital boost guage is tapped at like 13 lbs. Im thinking my injectors are stuck open or something. They are 55lb seimens. thanks alot.
i dont' see how they could just stick open, maybe one or two but 4 as your saying... get someone to crank it and listen, you can put a finger on an injector and you should be able to feel it working.
do you have fuel pressure? how about spark? i'd be suspect of a coil pack or module. maybe a crank or cam sensor but those sound unlikely. i'd be willing to bet its something simple.
You could also check your TPS incase for some odd reason it is signaling WOT.
found the problem i think. entire bulkhead going into the fuse panel is one big melted peice of gooey plastic :)
