Bryan,
This gauge works just like my "Methanol PSI' gauge I sell. The problem is how is this going to detect the fuel system is weak. Your fuel pressure lets say is set to 43 line off.. you run 20 PSI boost= 63 PSI fuel. So what do you set the warning too? 63 PSI.. anything below is a warning=spark cut? That means your on spark cut all the time. Like on my gauge I set 70 PSI.. when the needle goes past 70 it turns from red to white display.
I just dont see how to set the warning to do what you want. Unless i'm missing something.. then i'm all ears
The Dash from FAST that ties into with the XFI you can setup an air fuel alram.. air fuel goes past 12:1.. or whatever you set it too.. at WOT.. trips an output relay..
I dont know how you could cut spark.. dont think you'd want to do that as killing the engine you lose steering and brakes. At 130 MPH.. that could be very bad. You could actually blow the transmission killing the motor at that speed.
