I installed a Walbro pump and Hot Wire kit and now when the car sits overnight I have to crank it a lot before the pump will kick on. Once the pump starts running it fires right up and runs fine. The stock pump would kick on and prime as soon as the key was turned to Accessory. Why would it not do that now? I believe it's also losing fuel pressure while sitting. Leaking injector/injectors?
