New plugs, wires, coil pack and module and car has started to cough when boost starts to come up. under normal driving conditions car seems to be running fine, cut if you get into it a little and boost reaches around 5#'s or so car will start to cough, spit.
Car has a caspers hot wire kit....relay under the hood was shot (had melted plug). I was told that the relay that mounts by the tank takes the place of the one under the hood? I changed the relay under the hood anyway.
is my fuel pump shot or could the translator box/MAF have gone bad?
I'm in the process of trying to round up a pressure gauge to mount on hood so I can check pressures..
![Confused :confused: :confused:](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
